Throttle missing
Posted: Sun May 16, 2010 7:57 am
by laura 's Dad
Hi, I am missing the throttle for 1965 ca95 . The cable and wire are there but nothing else . Will anything else fit ?
Posted: Sun May 16, 2010 8:52 am
As long as you have the control all you need is a few parts
These parts are usually found on ebay. Search CA95 throttle.
You can find other 7/8 controls for other Honda'a with external throttle setups but you may have to modify or change the throttle cable.
The easiest way is to buy the replacement parts.
Posted: Sun May 16, 2010 9:40 am
Designed by a genius! I love these throttles. Only downside is that the selection of compatible aftermarket bars is limited... to almost zero.
Posted: Sun May 16, 2010 11:08 am
Good point. The replacement asian bars have no "slot" which renders the original throttle assembly useless.
If you have the original bars, then you are OK. I might have #13 in my stash of goods.
If you can't find one, let me know.
