CA95 and CA160 differences?
How can you tell the two apart besides engine/frame numbers?
The CA160 Seats, racks, tail lights, headlights, tank, side covers, battery, tool holder, tires, shocks, speedo are the same.
The wiring is a bit different as the condenser is behind the horn and the points are on the side of the cylinder head.
The mufflers ARE NOT the same! Big ebay error when you see mufflers that fit the CA95 and the CA160. I have the original mufflers on my CA160 and they mount differently than those on the CA95. The muffler itself looks identical.
The engines are night and day diffrent. The CA160 is way faster than the CA95. I will soon know if the engine mounts are the same. I have both bikes apart.
One goofy thing is I have a pair of plastic aftermarket asian Honda 150 badges that fit the 160. It's like putting a pic of your 1st wifes face on your 2nd wifes body.NOT...LOL
The engine feels a LOT smoother.. probably a result of better balancing, machining and the fact that the timing chain is now inbetween the cylinders instead of off to one side. Plus it's 10cc larger! It's like having a supercharger on it. No but seriously it's more powerful, probably a larger carb? I haven't measured it and I'm sure someone here knows. And the transmission gear ratios are different. Transmission is improved as well. I can pull up hills much easier on my CA160. I've also mentioned that I've been on the freeway doing 65 on my CA160. There is no way I could do that on my Benly. The engine would explode.
Today I removed the CA160 engine from its frame. I have an extra empty CA95 engine case, so for kicks I tried to fit it in, It fits. So for now, it looks like the CA160 engine will fit the CA95 frame. BUT....The CA160 wiring harness is slightly different, the ignition coil, although still 6V appears a bit different as well, but mounts in the same location.
As mentioned in another thread, I will have both the CA95 & CA160 torn down to bare bones. At that point I can do some pics. So far from my perspective today, with the major exception of the engines, both the 1965 CA95 and the 1968 CA160 are pretty much the same bike.
Got the CA160 broken down completely. Found a few more different aspects between the CA95 and the CA160.
1.) The CA160 chain tensioners are longer than the CA95.
2.) The sprocket hub and dampeners are slightly different.
3.) the chain guard that protects the swing arm from damage on the CA160 secures itself around the shaft mount. The CA95 chain guard just rests on the swing arm frame.
I wil be doing some comparison pics soon.
