Newbee here- I've been [secretly] spying on this website for some time now. I cant tell you how much I appreciate the knowledge Ive gained about these old Benly's. In fact, I've been able to fix EVERY problem I have had with this bike (just by searching this forum), except for just this one:
I've replaced the cylinders this winter. I decided this was necessary when, last summer, I would go for an easy ride, just 5-10 miles, and get up to 45-50MPH and the engine would seize! It had plenty of oil, I wasn't uphill, and I thought, briefly, that maybe the engine was overheating, and the pistons were sticking.
I cracked the top end off and notice the piston rings were no where near the correct spacing. In fact, they were never spaced from being new in the box. I decided this was the cause for so much stress. due to the minimal scraping on the sides of the pistons, and having wrong sized rings, I replaced them both. Sized the new rings at 0.012" and somehow both oil rings ended up at 0.013-0.014", aw-well. Finished putting it all back together, and kicked it and to my surprise, it started on the first kick. AWESOME!
Let it run for about 5 minutes, let it sit for several hours then took it for a spin after I figured out how the chain is supposed to go on.
I get home ok, but the next day I go to ride it to work (7 miles), and the little bugger siezes again! Im like,
so Now, Im thinking I may have an issue with oil delivery, because when I open the rocker inspection covers, the things are bone dry, barely any oil at all. I didnt notice this all the last winter, in fact I do remeber plenty of oil up there.
What am I missing?
Thanks for your advice, I cant tell you how may times I sat, counting for 30 seconds, searching for the answer.
