Do I have a Ca95???
Do I have a Ca95???
So, I was looking at this honda motorcycle that was in a shed on some family property. After doing some research I am pretty sure it is at ca95 just based on looks alone. The property is in a different state and I did not write down any serial number, but the tank emblem had honda and 150 on it. Would this be enough to distinguish it as a ca95? or do I need to drive the seven hours to find out? Any help would be appreciated.
If it says 'Honda 150' and you're in the USA, that would likely be a CA95. The CA92 was a 125, and the CA160 was a 160. Sounds like the bike has the original tank badges, since the Honda replacements simply had 'Honda' on them.
Get some pics and post them. The frame serial number can be a bear to find, especially if there's any corrosion, but the engine serial is quite easy, so if somebody there can provide the engine serial number to you, we can tell you more.
