CA92/CA95 Clutch thrust washer
DanUhr
Post by DanUhr »
I'm looking for a CA92/CA95 washer C, thrust 20mm
PN C902878 or 90453-200-000
It is supposed to be installed between the outer and center clutch.
It's in the parts book page 54 as item #13.
Does any one have the part to sell me?
Is it ok to install a standard washer? If so what is the thickness of the washer?
Dan U
I'll check in the morning and see what I have.
65ca95
Post by 65ca95 »
Check here if Smithers hasn't got one
http://www.atvhondaparts.com/fiche_sele ... 53-200-000
Sorry Dan! I looked all through my extra parts stash and couldn't find one. I have all the parts to make a spare clutch assembly but no washers at all. I can't recall fooling around with those washers before either.. I wonder if mine are even in my Honda. :)
DanUhr
Clutch washer from ATV-parts
Post by DanUhr »
No luck. They don't have it in stock. I've tried several other places but no luck there either. Thanks for the leads.
DanUhr
Found the washer
Post by DanUhr »
Found the part in New Jersey,
Great people to work with.
Thanks for the help guys.
Bergen Sport Cycles
http://bergensportcycle.com/
