Fork Lock woes.
Fork Lock woes.
The fork lock on my bike does not work so I took it off and PB Blasted it. Still no workie. The number on it is the same as my ignition lock and the key works fine in it. I wondered if anyone has any ideas? I thought about having a locksmith pick the lock and resetting it to my key. Any other options?
It is hard to say why the lock does not work. Assuming that there is no mechanical reason for the lock to be jammed.
1. Double check that the key matches the lock
2. Soak the lock in a warm phosphoric solution for 5-10 minutes (heat the water 1st and add the acid to water) This will eat up any rust. Rinse when done and lubricate.
3. Spray enough PB Blaster into a small jar or beaker deep enough to soak the whole unit for a day or two.
