Page 1 of 3
CA95, 6 volt to 12 volt Tutorial
Posted: Tue Jul 26, 2011 7:58 pm
Done.
Posted: Sun Mar 25, 2012 12:17 am
by scott12544
is that really all there is to it. I have wanted to install HID headlight on my benly
Posted: Sun Mar 25, 2012 8:36 am
by Coty_Jim
What battery did you use?(model code if available) Are you comfortable using the original horn and starter solenoid? I am considering the 12V conversion, but I haven't found a similar sized battery. Do you have the part/model # for the headlight and the indicator lights (neutral, high beam, and speedo illumination). The suggestion for conversion to HID is a good one, I have converted my CBX and ST1300 to HID with great success. More light and less electrical draw. Not sure it is necessary for the CA95, since it will probably not be a night owl, but could provide more visibility during the daylight hours.
Thanks for any info you might have.
Posted: Sun Mar 25, 2012 12:41 pm
Done.
Posted: Sun Mar 25, 2012 10:15 pm
by frappy
Jetblackchemist wrote: ... I suggest searching by the dimensions when looking and ...
Here's a link to a piece of Yuasa literature that provides measurements for all their currently available batteries. http://www.yuasabatteries.com/literature.php I've found it very useful when "upgrading" a motorcycle battery. After arriving at their website, click on the link entitled: "2011 Yuasa Battery Specifications & Applications (2.1 mb)". Happy hunting! :)
Posted: Wed Apr 11, 2012 10:05 am
by scott12544
what about the charging system. the 6v output will never keep the 12v battery charged. you would have to put it on a charger every night.
Posted: Wed Apr 11, 2012 10:15 am
by 92merc
I believe that is what the new bridge rectifier is for. Taking the 10kv and changing it to 12V instead of 6V.
Posted: Wed Apr 11, 2012 11:12 am
by comp_wiz101
scott12544 wrote:what about the charging system. the 6v output will never keep the 12v battery charged. you would have to put it on a charger every night.
The peak voltage output of the alternator is higher than 6V, but the battery acts as a regulator (load) to keep this lower. That's why you aren't supposed to run a bike like this without a battery (even if the ignition worked without it), it is designed to use the battery as a regulator.
Since engine is providing the same wattage @ 12V, doubling the voltage means current will be 1/2 the amount on 6V. (Because Power = Volts X Current). This is nice for a number of reasons, including lowering heat loss due to high current.
The newer rectifiers have a number of advantages, including lower heat, lower electrical noise, and higher voltage/current ratings.
I would recommend, if possible, including a 12V regulator in the circuit. It's not too likely to overcharge, but it's nice to reduce the odds of over driving the battery.
Posted: Wed Apr 11, 2012 11:13 am
by comp_wiz101
92merc wrote:I believe that is what the new bridge rectifier is for. Taking the 10kv and changing it to 12V instead of 6V.
Not exactly... a [silicon] bridge rectifier doesn't actually regulate the voltage down. It is more efficient, however, than the old selenium varieties. This leaves you with more power for driving the rest of the electrical system, instead of converting it into heat (That's why selenium rectifiers have those big heat fins).
Posted: Wed Apr 11, 2012 8:10 pm
Done.
Posted: Fri Apr 13, 2012 12:13 pm
by comp_wiz101
Jetblackchemist wrote:... you can use a regulator but you really don't need one.
Great to hear that it isn't a problem on these bikes. Thanks for sharing your experience.
Posted: Sun Apr 15, 2012 5:40 pm
Done.
Posted: Sat May 26, 2012 2:03 am
Done.
Posted: Sat May 26, 2012 5:12 am
I have been following this post with some intrest. Not that I am interested in converting from 6 to 12 volts, but just to see what happens.
I have cooked a coil by leaving the key in the on position and by random bad luck, the points were closed. I read earlier that you walked away leaving the key "on" and returning to that "smell" and seeing wax. I guess the lag time leaving the ignition "on" with 12 volts is shorter than with 6.
Thanks for the post. I am now convinced to leave my system alone and just cruise the bike in dry daylight trips.
Posted: Sat May 26, 2012 5:22 am
by Puzzleparadise
I have also followed this post and thanks to Jet I also converted over to 12 volt and never looked back..thanks for the info, it's appreciated! :)
Oh and I forgot to mention the 12 volt battery I'm using is a Yuasa #12N5.5-3B it was one he had off the shelf, (it has the polarity reversed from the original battery so it's installed with the terminals closer to the frame, so put a thick rubber pad against the frame to protect everything and it also keeps the battery from moving around a well!)
When I purchased the battery from my local Victory dealer he was convinced that the conversion wouldn't work! (He was convinced I was going to blow/fry every electrical component on the bike, lol)
