Product report. Head light
weestrom05
Post by weestrom05 »
The reproduction headlight arrived from Thialand today. It took exctly one month for delivery.The light looks close enough from the outside that i doubt anyone would notice the difference. On the inside of the light it is obvious as the reflector is plastic not steel as the original. I havent looked at the bulb in it to see what it is to know how readily available it is. Overall Im satisified with it and the delivery time was as promised.
Curt
comp_wiz101
Post by comp_wiz101 »
Thanks for the report! I need to replace my headlamp too, and I'm also wondering about how easy it is to find replacement bulbs for the Thai repros.
weestrom05
wiring the repro light
The jumper wire that hooksup the bright light indicator is in the headlight bucket. At least in mine. The only changes that i have found is the wire colors is reversed with the red and blue wires. There is also no hookup point for the black ground wire. I had to put a spade lug on it and connect it to the bezel screw. Other than that it worke well.
Curt
