Posted: Sun Dec 16, 2007 9:07 pm
So when I finally go the guts to hook up the battery and give it a kick it sputtered right off!! I was surprised as hell. I didn't even think it would fire but it did. But then it didn't want to start after that! What the hell!?
It basically wasn't getting fuel after that. Yeah when I took the carb off I cleaned it up a little and scooped all the gunk out of the bowl but that was about it. The only thing I didn't do was take the jets out and clean them at all. This was my shortcoming and I was just in a hurry.
** YOU MUST CLEAN OUT THE JETS AND FUEL PASSAGEWAYS ON ANY HONDA CARB **
Today I finally had a little time this afternoon to clean out the garage space some and take a look at the carb on the little monster. The mainjet looked OK but still needed a little residue removed from the inside. BUT the little jet was COMPLETELY blocked. Not even a needle would go through it!! So now it's sitting in a pan soaking in some carb cleaner. I have a picture of it bathing in the stuff and I also threw in the mainjet and a couple of other little pieces. I will be happy to see it clear up tomorrow.
Oh by the way in order to get this little guy out of it's home GET THE NEWEST SCREWDRIVER YOU HAVE that fits perfectly into the passageway where it sits inside. It's very important that you don't mess up the jet when you are trying to break it free. You will be in deep Shiz if you fail to remove it the first time and damage the jet.
From left to right - idlejet / mainjet / seat screw for the float needle.
The breather / vent holes are the brass inserts which are above and below the mainjet.
