What really stinks is that I had to clean the parts while I was taking them apart. Be super careful when you disassemble everything in order to preserve the pieces to be used again. Forget the bowl seals as you will replace them with o-rings but the packing inside the fuel petcock MUST BE PRESERVED. I've never seen new packing pieces for sale and a whole new CA95 petcock assembly will easily demand a price of $200 on the Honda black market. After some painful cleaning and sweating the disassembly process this is what I had to work with:
As you can see I have cleaned these quite a bit! They were completely encrusted in old fuel varnish. You couldn't even tell what was inside once you removed the Honda petcock assembly from the tank. To get it off the tank you have to remove 3 VERY stubborn phillips screws that you will discover once you take off the fuel bowl. Clean the crap out of the screw head and grab your best T-Handle phillips tool if you want to have a chance at breaking them loose. They are long and enter the actually fuel tank so if there is rust in your tank you will not be able to back out the rusty portion of the screw threads. My spare petcock had to be removed from the rusty tank with my trusty Dremel tool. I used the small blades to cut the tops of the screws off. It was miserable work but I needed to see the condition of the parts.
I visited my friends transmission shop and consulted his BIG BOX of O-Rings! They have a box FILLED with every o-ring ever made... every size and every material. I found a couple that would work and snuck them out quickly. I don't think they invented o-rings yet when they produced these bikes or else they would have used them!! This should surely make a better seal than some original gaskets. And they were freeeeeeee
