Honda CA95 Indiana Spokes New Project
The fittings in the filter are hollow wiring bolts from the bullet lights I modify for turn signals. I drill a pilot hole in the back of the filter and enlarge the hole with a taper machinist reemer. The filter is mounted on the original extension that would originally it woud fit into the extension tube. But do remember at this time it is experimental. I will update this thread after the engine is installed.
Chip can you cut down on hoses by using a vacuum "T" at the carb vent? Additionally these clear tubes will get "ugly" over time- maybe just black vac hose (or colored silicone to match the bike color)?
Also makes you wonder if an intake tube from say an S90 (or similar) would cant the carb enough so the filter could be just to the side of the down tube frame structure.
Absolutly. My tube experiment was done on a brain cramp moment idea. I ran the Build from Scratch bike for a year with the engine just venting to the atmosphere without any noticable problems. Changing the clear tubing to black vacuum tubing would be a better idea and the vacuum "T" is probably a better idea as well.
Retro fitting parts from other models is also a way to go. Thanks for the input.
In the past I always rebuilt the whole bike and then debugged. This time the engine has been mounted on the Build from Scratch CA95 to put some miles on the engine while I finish the paint on the front fender & chain guard on it's frame. Tomorrow the pipes, ignition, and the cam end caps. The tank will be mounted and fueled up. I will take a vid of the engine starting up for the first time since 1981
Interesting comment Sam. The engine & bike have CA95E & CA95 numbers stamped on the frame. It is a 1964. The serial numbers are in the 22000 rangs making it a late 1964. As far as I can tell the bike & engine were untouched and sat for 32 years.
Maybe you see something I don't. I had to put off the starting of the engine for a day, but there is lots of compression
I grade myself on every build I take on. This time I decided to hang the engine on my daily rider. Even though I take on the worst of the worst project bikes, I always try to get the rebuild perfect. There is nothing I like better than knowing that I took a 32 year still, corroded engine and made it new again, started her up and took off down the road.
But alas the perfect score eludes me once again. The engine started super fast and idled like new. I ran it around my private lake oval. Ran strong, shifted smooth, no rocker noise, no smoke and I was temped to let her go to see what the top end may be.
But..I have an oil leak at the top engine mount. Off with the engine to find out what I did wrong (yes I know I took the pic with the domed nut removed already)
Spokes wrote:Interesting comment Sam. The engine & bike have CA95E & CA95 numbers stamped on the frame. It is a 1964. The serial numbers are in the 22000 rangs making it a late 1964. As far as I can tell the bike & engine were untouched and sat for 32 years.
The long exhaust stud nuts Chip, that's unless the CA95 had them as well, can't say I noticed them before.
I just checked back on some restorations, seems they were OEM on the CA, the C95 just had ordinary length nuts.
Time Stamp 6-8-2013
The engine runs fine after 60 miles. It's time to transplant the motor. Today is finalizing the wiring here is shot as she sits.
The 2nd hardest part(after the frame) to restore was the front fender
This is one of my favorite before & after pics:
Before
After
More pics later. But just as a teaser, I found a set of original Honda 150 tank badges in sad shape for $15. The restored badges are a real goodie on the restored tank.
Before
After
