Bent gearshift lever
Ranchman
Post by Ranchman »
My first problem.
I found I have a bent gearshift lever (picture 1). It was very hard getting the left cover off. I removed the right crankcase cover, clutch pack, outer clutch, circlip and washer. Should the gearshift lever pull straight out now. ( picture 2 )
Something a bit odd. Look how clean the inside is. I was expecting black tar when I pulled the crankcase cover. Picture #3
Thanks in advance, Ranchman
Yes, it should pull straight out. The engine is strangely clean. A wild guess is that someone rebuilt the engine and it fell off the bench, bending the shifter. Is that a weld I see behind the shift arm? If so, find a donor engine and harvest the case and shift arm. The engine parts from 64 & 65 are interchangable. The tranny gears from the earlier years work. My "Build from Scratch" project engine is made up of:
64 Bottom end
65 Top end
62 Cylinder
62 Tranny gears
64 head
62 pistons.....it runs pretty nice. Honed the cylinders with a brake hone. Fine sanded the head on a flat surface, lapped the valves, threw in some new rings & gaskets...
Ranchman
Post by Ranchman »
Thank you spokes,
I think it's being a pain because it's bent. I just wanted to make sure I wasn't missing anything.
I looked no weld. I think the background is out of focus.
I'm thinking your right it's been rebuilt. The clutches look new also. Funny it was rebuilt then sat for all those years.
Ranchman
Done.
Last edited by Jetblackchemist on Fri Nov 09, 2012 10:31 pm, edited 1 time in total.
Hmm yes that's bent.
You are lucky that sucker is so clean. And the gasket came apart just like that? Yeah it's been well cared for. I wonder if I have a shift shaft laying around...
Rancher , if it was my motor ,I'd slip a piece of pipe over the shaft and slowly bend it back in shape . The shaft is supported at both sides of the case .
I too have straightened a shift lever and kick start lever (CT90) with good results. Just be careful to not bugger the splines. I applied a little heat as well. IF the bike had been laid down as mine was inspect the cover for cracks around the seal boss too.
I'd bet Spokes could shake a box with spare parts in it and a perfect engine would fall right out- I just love that guy- in strictly bromance kind of way.
Here is my spare here. Straight as an arrow. The splines show some wear although the shifter slides on and off good. $23 shipped. You can see the chain flew off and it damaged the clutch actuator rod. That's how this engine was decommissioned.
Ranchman
Post by Ranchman »
Smithers I'll take that deal. Let me know where to send $$. I'll be replacing the shaft seal. If you or anyone has a favorite place for CA95 seals please let me know.
Thanks, Ranchman
Ranchman
Post by Ranchman »
kartgreen wrote:Rancher , if it was my motor ,I'd slip a piece of pipe over the shaft and slowly bend it back in shape . The shaft is supported at both sides of the case .
Thanks Kartgreen and Larzfromarz that's what I ended up doing to get it out. It has a s bend in it. So I'm going for a straight one from smithers.
The shaft is yours. I just pick up seal kits on Ebay as I have found them pretty cheap. And we always end up needing the kick starter seal as well so they add up FAST when you need them one by one. A kit can be found for 10-$20.
