Will a CA160 engine fit a CA95?
Steverinomeiste
Post by Steverinomeiste »
I am just curious. Will the 160 engine fit my CA95? Or, are parts interchangable. Is the cam chain on the left side or between the pistons on those? I've noticed the drive chain is on the left side. i haven't seen a 160 in person so that's all I can tell from pictures I've seen online.
Thanks
Steve
Yes. The CA160 engine & exhaust pipes will fit the CA95 frame.
You have to use the CA160 wiring harness though. All other parts are interchangable with the exception of mixing the upper & lower chain guards between both models.
Steverinomeiste
Thanks Spokes, I am just thinking of a back up plan if getting my crank rebuilt doesn't pan out. I've sent an email to Mr. Crank in Kentucky and waiting to hear.
Steve
