Carb Spring?
Sea Monkey
Carb Spring?
Post by Sea Monkey »
So I'm SO close to getting my 64 benly on the road. However, one of the things that was strange to me was how gummed up and hard to turn the throttle was- I assumed it was the cable. However, upon closer inspection, I found that the previous owner had used a way stiffer spring in the carb (the one that maintains tension on the throttle cable. These aren't included in rebuild kits- ANYBODY KNOW WHERE I CAN GET ONE? There was one on ebay (with random bits from a carb), but it sold- plus, $25 seemed a bit steep...
Man, it's getting warmer here and I'm itchin' to get that bike on the road!!
Check out a hardware store for a spring ,my local Ace Hardware has a great selection of springs . you may have to buy one and cut it down to the correct length and tension .
I have a spring from another old Honda carb that is very close to the original CA95 type that may(likely) work. PM me with an address and I will send it to you.
It's just sittin in my misc Honda parts box.
