I'm going to look into having the rims rechromed, but failing that, are people generally buying the UNION CYCLE stamped rims from Thailand as replacements?
At $130 or so shipped for a pair, they're not expensive, but I'd be happy to spend another $100 if it meant getting a higher quality rim.
MikesXS.com sells very nice polished 36 hole WM style alloy rims for $90 a pop, but the 16" size is a WM2.5 rim width which is I believe significantly wider than the stock C95 rims.
Any tips / suggestions on which rims to source? I'd like to put this thing up on 2 wheels so I can finish it off.
