Quick (I hope :rolleyes
New points (set to 0.35mm)
New advance mechanism
New condenser
the locating knob on the advance mechanism is located correctly
What am I missing?.....
.....or is this normal?
Thanks,
Kev.
I also experienced a similar issue before realizing that my point gap was too large (larger dwell angle). Once I got the point gap set correctly, the static timing setting fell within the range of the backing plate's movement.Sam Green wrote:In a nutshell, if you run out of adjustment on the points backing plate, chances are that the generator cover has not gone on central to the crankshaft.
