Rubber covers for clutch and brake adjusters
1911tex
Post by 1911tex »
These slip over the knurled adjusters at cable end at handlebar.....were they available for the Benlys? If so, where available? I had one only over the clutch lever adjuster on my '63, but was split open and useless.
I also have a Honda CM200 1980 with the covers in great condition. Went to the ebay CM200 parts site and could not find them...they fit perfectly on the Benly.
Only reason I ask is that these rubber covers really clean up the look of and keep grime out those knurled adusters. I looked at early ad photos of the Benlys and could not tell if they came as original equipment.
I didn't see any rubber covers for the lever-mounted adjusters in the parts manual.
1911tex
Post by 1911tex »
Here is a picture of the covers I am referencing...ByTheLake, I did not see them in the CA95 manual as well, but one torn-up one was on my CA95:
http://www.hondarestoration.com/fiche_f ... _model199/
If this does not download properly, the OEM # is 53171-402-700 and it is called a cover handle lever...however, shows for an '80 CM200.
