Carburetor swap
comp_wiz101
Jetblackchemist wrote:It's like trying to pour something from one container to another...with a funnel, it's more efficient to get fluid in pouring into the large end of the funnel out of the smaller into the container, than it is flipping that funnel over.
Great analogy, it illustrates the point well. I've been getting interested in carburetor theory lately with my carb-swapping my first 2-stroke - fitting the little bugger is quite the adventure.
Has anyone actually used an aftermarket carb successfully? I would like to know which one and how they went about jetting it. I know I am in the CA95 thread, but I have a CA160 with the air adjustment screw broken off inside the hole and the tube that the fuel line goes on is leaking like a sieve. I can't find an original carb anywhere and would be thrilled if I could get an aftermarket to work. Anybody ever try to drill out an air screw? Been able to do it successfully? Suggestions to stop the leak on the inlet tube? It leaks out around tube and the opening it goes into on the carb.
comp_wiz101
grubsie wrote:Has anyone actually used an aftermarket carb successfully? I would like to know which one and how they went about jetting it. I know I am in the CA95 thread, but I have a CA160 with the air adjustment screw broken off inside the hole and the tube that the fuel line goes on is leaking like a sieve. I can't find an original carb anywhere and would be thrilled if I could get an aftermarket to work. Anybody ever try to drill out an air screw? Been able to do it successfully? Suggestions to stop the leak on the inlet tube? It leaks out around tube and the opening it goes into on the carb.
If it is a press-fit brass fuel inlet, you might have luck with a gas-resistant adhesive.
scott12544
