Go Back   FourWheelForum > Motorcycles & Streetbikes! > The Honda CA95 / Benly 150 Restoration
The Honda CA95 / Benly 150 Restoration The little brother to the CA160 in our family of Hondas
Unread 05-16-2018, 08:27 AM
wnbasac wnbasac is offline
Default oem parts list
not all parts apply to dreams but if you see something Let Me Know
PART# & QTY / shipping is split
list is posted on other bike forums / i'll update list as parts sell
tks,lou
Part # Qty Cost ea Description Cost all
11398-426-000 3 $6 oil pan gasket $ 16
15420-300-020 1 $7 oil filter bolt
154a1-413-505 1 $5 oil filter O-Ring
15410-426-010 3 $7 oil filter $ 18
17631-329-003 3 $2 gas cap packing $7
18291-mn5-650 4 all exhaust gasket $10
30201-003-004 1 $3 points base plate
30251-003-004 1 $8 condenser
30372-300-300 1 $4 point cover gasket
35317-001-310 1 both horn button All $ 11.00
35318-001-310 1 $11 horn spring spring
45105-ma5-305 2 $15 brake pads
45435-250-000 2 $2 frt brake spring
53161-250-000 2 $3 throttle wire hinge
53192-203-000 2 $7 cable adjuster
83650-003-000 2 $6 side cover latch bolt
87020-070-010 2 $20 fuel tank emblem
90407-259-000 5 $7.00 oil drain washer
90452-200-000 2 $2 washer B 20MM
91302-377-000 11 $4 oil filter bolt O-ring $ 26
91306-413-000 2 $4 oil filter gasket
91307-425-003 3 $3 oil stick cap O-Ring $ 8
91302-mg7-003 1 $3 oil pan O-Ring
91316-425-003 4 $4.00 oil filter case O-Ring $ 16
92800-12000 1 $5 drain bolt
94109-12000 11 $1.50 drain plug washer $ 11
95015-32001 4 $2 frt brake joint
95015-42000 4 $2 brake rod adj screw
98069-57911 4 $16 spark plugs
17620-402-010 1 $20 gas cap
32411-230-000 2 $5 starter cover boot
31201-292-158 1 all starter brushes
31204-292-158 2 $20 brush springs
31206-402-008 1 oil seal O-Ring
91012-202-010 1 $25 CA95 Bearing
SCREWS & BOLTS
90114-310-000 4 $2.50 handle lever bolt $ 12
92101-060080a 8 $2 ea 6x8 hex bolt $ 14
92101-060160b 8 $2 ea 6x16 hex bolt $10
92101-060200a 6 $2 ea 6x20 hex bolt $ 10
92101-060250b 10 $2 ea 6x25 hex bolt $ 14
92101-060450a 2 $4 6x45 hex bolt
92101-080200a 6 $2 ea 8x20 hex bolt $8
92101-080250a 6 $2 ea 8x25 hex bolt $8
93500-04004-04 4 $6 4x4 pan screw
93500-05025-0b 12 $1.50 ea 5x25 pan screw $ 14
93500-050-080a 4 $3 5x8 pan screw
93500-050120a 8 $2 ea 5x12 pan screw $12
93500-050160b 6 $1.50 ea 5x16 pan screw $ 1.50 ea
93500-050200a 8 $12 5x20 pan screw $ 8
93500-050-220a4 $2 5x22 pan screw
93500-060120b 5 $10 6x12 pan screw
93500-060160a 6 $1.50 ea 6x16 pan screw $ 10
93500-060180a 4 $1.50 ea 6x18 pan screw $6
93500-060200a 5 $1.050 ea 6x20 pan screw $ 9
93500-060250a 6 $1.50 ea 6x25 pan screw $ 10
93500-060300a 5 $1.50 ea 6x30 pan screw $ 7
93500-060350a 10 $2 ea 6x35 pan screw $ 18
93500-060400a 6 $2 ea 6x40 pan screw $10
93500-06045-0a3 $2.50 ea 6x45 pan screw $6
93500-06060-0a3 $2.50 ea 6x60 pan screw $ 6
93500-060750a 3 $6 6x75 pan screw
94021-08020-0s 9 $2 ea 8MM acorn caps $ 15
94021-100200s 6 $3 10MM acron nuts
93700-030600a 19 $2 ea 3x60 oval screw $25
93700-05016-0a6 $2 ea 5x16 oval screw $ 10
93700-05030 6 $2 ea 5x30 oval screw $ 8
93700-060160a 8 $2 ea 6x16 oval screw $ 10
93700-060200a 16 $2 ea 6x20 oval screw $ 25
93700-060320b 4 $10 6x32 oval screw
96201-30001 9 $2 ea grease nipples $ 15
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
