Unread 04-03-2015, 06:27 AM
kartgreen kartgreen is offline
Default exhaut gaskets
If your tired of the goofy wire wound sealing gaskets for the exhaust port try a Harley Sportster part ! Sportsters from 2004 and up have a crossover or connecting pipe between the mufflers that use a grafoil type gasket that works very well as a replacement for the gasket on the CA95's exhaust port .
Harley part # 65927-00 / $ 3.62 for 2 .
Unread 04-03-2015, 07:21 PM
Roberd42's Avatar
Roberd42 Roberd42 is offline
I used the copper bmw gaskets and cut them down to fit. Good to know another option. Thanks for sharing!
Unread 04-05-2015, 09:44 AM
Awesome. Old exhuast joint gaskets and manifold gaskets are the lowest technology on any motorcycle up until the 90's. Very frustrating.
Unread 04-14-2015, 01:30 AM
ByTheLake's Avatar
I used copper Ducati gaskets, which were a perfect fit. The details are in this thread, along with pictures:
http://www.fourwheelforum.com/showth...=ducati&page=2
Unread 04-14-2015, 03:27 AM
Roberd42's Avatar
I ordered two from bevel heaven. He still only had only one in stock (as kev had mentioned) and terminated my order. I found a close one on a bulk retailer website but it was 1 mm too small and 1mm too thick. I forwarded that info to bevel heaven as he was interested in a supplier. I ended up using the k100 BMW copper cut down two or three mm into a spring that held itself in well while I mounted the pipes, just like kart green on that thread. Works great so far. Plus I got 4 for $8 on eBay used. I just annealed them before installing.
